Help code 36
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
Help code 36
I have it on
it it possible to have on after the valves are adujted
I have a mass new 2 years ago that did have the burn off in it and Scott hansen deleted it
And now tuned performance chip and I told them but I don't think he did it
engine light is on full time
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help code 36
Like I mentioned have had issues with disabling code 36 in conjunction with vats.
not sure if it’s a tuner cat issue or what. Regardless you still need to datalog tune your car and the flag can be
unchecked at any time. You pleaded for a starter tune. That’s what you have if you need a refund for labor send me a message.
Engine: 383 built
Re: Help code 36
Engine: 383 built
Engine: Lb9
Transmission: M20
Re: Help code 36
Aye Yai Yai!
