88 Irocz won't start
Old Oct 9, 2021 | 12:24 PM
Pink88's Avatar
Looking for suggestions..my 88 Irocz won't start replaced starter and battery will crank over now but seem like not getting fire
Old Oct 10, 2021 | 09:27 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 88 Irocz won't start
Spark ? Fuel pressure? Efi ? Injector pulse ?
Old Oct 13, 2021 | 02:45 PM
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
Very loaded question - much to resolve before you start pulling things apart. Sometimes a visual check is good but if nothing shows:
Does the SES light come on? It should be steady when the ignition is "on" and the engine stopped. If not , there is an ECM issue and/or a blown fuse.
Terminal's B1/C16 , Orange Wires, must have 12V.
If the light does come on - best thing to do is ground the diagnostic terminal and note the code flashing. Jumper terminal "A" to "B". Code 12
should be the first to flash to indicate the ECM is working properly. It will flash 3 times followed by 'trouble' codes.
Old Oct 14, 2021 | 09:15 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Which systems have you already checked, and what was the result?
TimMcLeod
Mar 19, 2014 04:49 PM
mcdelrio
Oct 6, 2004 01:33 PM
gunnman54
Nov 22, 2000 10:15 AM
