Bird 2.8l V6 wont start
Old Oct 17, 2021 | 06:56 AM
Speeddemon1's Avatar
Hi, everyone ,i have a little problem with my Birdy ,he wont start no more
yesterday he run rough and THE other day no starting ,
my cooling fan always run with the key on,but now this thing wont my fan dosent work
THE fuel pump primes 2seconds and THE injector click THE engine turns over good
i have no sprak and no spark at THE plugs
And the cooling fan dont turn on with THE airconditioning (single fan )
so what can iT be 😞
the bird is a 1987 V6 mpfi automatic trans 2.8l
Old Oct 18, 2021 | 07:41 AM
Re: Bird 2.8l V6 wont start
I have try to track te codes ,but when i have a paper clip in a and b and and i turn THE
key to run my fuse Burns at a junction block on THE front passinger Side.
and i cant THE code then he says code 12 because THE burnt fuse
i tryd a wire between junction block with out THE fuse and THE wire burnt of
my cooling fan whas on but now wont turn ,with direct 12v no problem
my gas pump wont prime with Cold Cold start ,only with oil pressure then i can hear THE pump
when i conect a 12v wire to terminal g THE pump does nothing
Old Oct 18, 2021 | 01:36 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
look for a short-circuited wire and also suspect the fan motor could be bad and blowing the fuse-temporarily disconnect the fan motor and see if the fuse still blows.
Old Oct 18, 2021 | 01:59 PM
Hi, Thanks for THE info i wil take a look a that Tomorrow
Old Oct 19, 2021 | 04:58 AM
Hi THE fan is good i have put direct 12v to iT and iT turns good ,
Now i have a anthor problem ,now THE fuel pump keep running with out THE key trurn over
Old Oct 19, 2021 | 07:41 AM
I have swap THE relay,s and THE pump prims normal ,i chance them back and THE pump runs good normal
i had THE oilsensor pull out And stil normal priming ,
when i pull THE relay and crank THE motor when there is pressure oil then came THE pump on
,so i put all THE relay,s and oilsensor back and THE fuse in THE junction block and set THE key in start (run)
the pump prims fuse not blown and all work good ,but still no cooling fan and no starting
is there maybe a fuse link ,or is the fan conected to the starting (coil igm)
Old Oct 20, 2021 | 05:19 AM
Hi ,this is what THE motor does,
1 iT turn over good
2 i have fuel pump
3 cooling fan works with direct 12v hooked up
4 THE ses works when crank and stays on with key on
5 injectors clicking
now when i hooked THE a and b obd THE fuse pops at THE junction block under THE Hood
so i cant check THE code,s
the car wont start and THE fan dont work
but what are THE fuse links on THE starter
does Some body now want is wrong
Old Oct 21, 2021 | 03:31 AM
No i have my fan running normal ,fuel pump good
i put a screwdriver in THE coil wire no spark ,and no spark at THE plugs
starter turning good ,
still no start
bmxerboi221
Oct 31, 2008 08:55 PM
tilstad
Jun 10, 2004 02:40 PM
maverick544
Feb 22, 2002 06:03 PM
