TPS Question??
Old Nov 6, 2021 | 03:14 PM
jimbear56's Avatar
TPS Question??
I have 1988 RS with 2.8 v6. 183000 on clock. Not exactly what it's problem is but this what is happening. If I don't drive it for couple days it will operate fine for 10 /12 miles and
then start acting not getting fuel will "stutter" and buck if try to accelerate even a little bit, some times after 20 miles or so and a stop, it runs fine no issues. If driven regularly no
problem, Changed fuel filter last summer, use injector cleaner every 4th tank of gas. What I think it may have something to do with the TPS the original is still on it. Have anyone else have problem like this?? Any good ideas appreciated. Thanks in advance
Old Nov 6, 2021 | 06:16 PM
Re: TPS Question??
Doesn't sound like a TPS problem. The TPS reads the same hot or cold, 10 miles or 10,000.
Sounds more like fuel delivery. Bad injectors, bad FPR, bad fuel pump, etc. FUEL.
Although it's not impossible that it's the coolant temp sensor; when the ECM begins paying attention to it and using it in its fuel delivery algorithm, it tells it the temp is something COMPETELY out in the ozone. Maybe, it isn't even connected. Might be a good thing to check.
Great place to start would be, what is the fuel pressure WHILE IT'S IN THE ACT OF SCREWING UP. NOT, while it's sitting in the driveway happily idling; WHILE IT'S IN THE ACT OF SCREWING UP. Tape your FP gauge to the windshield and watch it as it goes through the change from running OK to screwing up. Get the FP reading WHILE IT'S IN THE ACT OF SCREWING UP,
In case I forgot to mention: the operative concept here is, WHILE IT'S IN THE ACT OF SCREWING UP, WHILE IT'S IN THE ACT OF SCREWING UP. Gotta catch it in the act of SCREWING UP and see what it's doing wrong.
Old Nov 13, 2021 | 04:05 AM
jimbear56's Avatar
Re: TPS Question??
thanks some things to check out. It is time to put it in " hibernation" for winter, going south for winter.
Vinscully50
Jul 2, 2020 11:24 PM
nbrittenham
Feb 11, 2013 04:11 PM
jimc1987
Apr 14, 2009 08:00 PM
Wootah
Dec 17, 2002 10:31 PM
89blackGTA
Sep 9, 2002 01:28 PM
