Piston ring end gap
Old Nov 21, 2021 | 10:02 AM
Johny2234's Avatar
Car: 1990 Trans Am
Engine: 383 stroker
Piston ring end gap
What should my piston ring end gap be for a sealed power hypereutectic piston that is a 4.030 inch bore. It's a 383 stroker that will be driven mainly on the street, but might see some hard driving at times.
Old Nov 21, 2021 | 10:14 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Piston ring end gap
What Sealed Power states in their instructions. My Weisco forged pistons in my 383 worked out to 0.014" upper ring and 0.016" lower compression ring based off their clearance specs at a 0.030" over bore.
Old Nov 21, 2021 | 10:22 AM
Johny2234's Avatar
Car: 1990 Trans Am
Engine: 383 stroker
The instructions only stated how to put the rings on. There was no mention of ring end gap unfortunately.
Old Nov 21, 2021 | 12:04 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Rule of thumb is .004" gap per inch of bore size, but you'd do well to contact the manufacturer and get the specific recommendation for your particular ring set.
Old Nov 21, 2021 | 01:40 PM
Hypereutectic pistons shed heat far less than forged or even normal cast ones, therefore the rings get a good bit hotter, therefore their end gaps have to be a bit looser than others.
If you have a little too much gap, or even ALOT too much, the worst that happens is, a slight extra amount of blowby. (emphasis on SLIGHT) If you have ANY too little, even just .001", DISASTER strikes. The ends butt together when they get hot, which makes their OD greater than the ID of the bore; the least severe thing that will result is blowing the ring lands off of the piston, and can get ALOT worse from there. Up to and including, seizing to the bore, gouging it, and so on.
I know which side I'd rather err towards.
Rule of thumb for hypers is .0045" end gap per bore inch for a "normal" application, on the top ring; open up a half to a whole thou for a "hot street" or "street/strip" deal, and another thou if typical street amounts of nitrous or forced induction are involved. About an addl half thou to ¾ thou on the 2nd. I'd set up one like yours at about .020" on the top and about .023" on the 2nd, if it was mine.
Last edited by sofakingdom; Nov 23, 2021 at 08:50 PM. Reason: Raw stupidity flowing from my last 2 brain cells to my fingers
Old Nov 21, 2021 | 10:39 PM
vorteciroc's Avatar
Top Answer: 1
What material and design are the Top Rings, and Second Rings?
We can provide a definitive recommendation with more information.
Sofakingdom gave you a great recommendation for not knowing more about what you have.
There are many factors to consider, and many variables (which you could minimize by posting the details).
Old Nov 23, 2021 | 03:28 AM
NoEmissions84TA's Avatar
A piston manufacturer has no idea what rings will be run on a particular piston. The combinations are endless.
That's why you need to ask the ring manufacturer what gap to use for your situation.
Usually, they are more than happy to help.
rigbyscamaro89
May 10, 2010 09:05 PM
twink_893
Feb 25, 2005 08:11 PM
89formula#1
Jul 16, 2003 10:37 AM
badazz84camaro
May 3, 2003 07:50 PM
radiateu2
Nov 13, 2002 09:10 AM
