Hard to Get Key Out of Ignition
Old Feb 4, 2022 | 01:04 PM
GTA88's Avatar
Posting this because I wonder if something is going wrong. It's not a big deal to spend 15 seconds wiggling the key out, but why?
The key goes in fairly easy, but not exactly silky smooth.
Getting it out is much harder. Have to wiggle it around and slowly work it out.
Spray some silicone or graphite into it? Would that screw something up?
The problem started about 2 years ago. Not getting any worse, but still, why?
88 GTA and the key has the standard chip mounted on it.
Old Feb 4, 2022 | 01:08 PM
Re: Hard to Get Key Out of Ignition
WD-40 is the usual thing. Doesn't gum up near as bad as the others.
Old Feb 4, 2022 | 01:32 PM
GTA88's Avatar
I have a spray can of 'Lock-Ease' Graphited Lock Fluid with a snorkel attached. I'll try that. It says it is for all types of locks. Ignition is not a lock (or is it?) , but similar, so I guess it can't hurt.
Old Feb 4, 2022 | 01:34 PM
Where the key goes, it might as well be a lock; same mechanics (pins, tumbler, cylinder, etc.), just, a different end result. So yeah, worth a try.
Kyoht
Sep 5, 2014 07:12 PM
DennisCarithers
Jun 16, 2012 08:13 PM
89TPI350
Aug 11, 2005 01:00 PM
SAEspinz80
Oct 29, 2002 07:14 PM
