89 IROC 5.7 not charging
Old Feb 15, 2022 | 06:58 AM
Surgical1969's Avatar
Car: 89 Camaro IROC Z28
Engine: 5.7 L
Car: no mods, bought off the floor in 1989 garage kept since
Issue: 11.4 V and dropping at battery terminals while running. New Optima battery, second new alternator. First Alt I suspected POS rebuild, installed second from different vendor same issue. Terminals clean, fuses under dash all good. Where now? Thanks.
Old Feb 15, 2022 | 08:20 AM
Johnny Gun's Avatar
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
Re: 89 IROC 5.7 not charging
You have a short somewhere.
Old Feb 15, 2022 | 11:26 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Unfortunately I dont have anything to add for your charging problem, but I see this is your first post here and I always like seeing members who have owned their Thirdgen this whole time since purchasing it new. Well done and thank you for keeping a cool car all these years. Wish I could go back in time and buy one new.
Old Feb 15, 2022 | 01:00 PM
69-er's Avatar
What's the voltage at the alternator terminal? A quick check to see if the alternator is working is to place a steel tool at the back bearing area while running. That area will be magnetic.
Do you have wiring diagrams?
Old Feb 15, 2022 | 02:59 PM
OrangeBird's Avatar
Car: 1989 Firebird
More likely an "open" VS a "short"....
Short circuits draw too much current. This leads to blown fuses/fusible links in the best case, or melted wires, burnt components, and release of the magic smoke sometimes coupled with fire in the worst case. Open circuits simply cause stuff to quietly stop working, without all of the biblical fire & brimstone that shorts sometimes cause. If I were the OP I'd be taking voltmeter reading of all three* of the alternator's connections with the engine running and post up the results here .......
* the one big terminal with the fat wire and the two skinnier wires going to the plug .
Old Feb 17, 2022 | 02:32 AM
vorteciroc's Avatar
Top Answer: 1
I would recommend conducting a Parasitic-Draw Test, with a Multi-Meter connected to the Battery in Series.
hernandeze
Mar 3, 2015 12:15 AM
aariccc
Nov 18, 2010 03:45 PM
chevylove87
Jun 3, 2009 11:44 PM
steeljab
Feb 7, 2009 12:19 AM
Zrated83
Aug 19, 2006 10:26 PM
