dead battery
Car: 87' Camaro
Engine: 305 carbed
dead battery
okay, so my alternator is just a couple months old, should be good its reman by a quality shop. has no problem running the car with a dead battery/no battery, but my battery will die after about 4-5 days of driving 20mins at night. from what i can tell it is hokked up correctly (just finished my 2nd motor swap so it was off and disconnected for a bit, but its just two wires, how can i go wrong?)
ideas? one of the wires off the alternator has a black lump in the wire, fuse maybe?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Monitor the voltage.
Wire, DIRECTLY TO THE BATTERY, a test instrument grade voltmeter.
When you start a cold car you should see the voltage move up to about 14.5, then slowly decrease as it warms.
When you’re driving, the voltage should never drop below 12.5.
With an ammeter, check your circuits for a draw after shutdown.
How old is the battery?
If it’s near the expiration date dump it.
Happy Racing!
If People Drove Any Slower They’d Be Going BackwardsHow bout those dorks too scared to drive without headlights on in the day time!
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: dead battery
How old is the battery? It's possible that your alternator isn't charging "enough". Believe it or not, Sears is able to do a full battery/charging system check (I know, I work there in Automotive) that's fairly reliable. Also, thing about batteries. They can be good for a year, then go to crap for no reason. Also, if they sit with no charge for a while, they tend to go bad. Like a car, they need to be used to stay in good shape.
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: dead battery
could be a bad alt, i got 2 bad ones from nappa, finally went to autozone and got a good one, have them test it before you walk out the door with it
raymondandretti
Sep 27, 2015 06:43 PM
