Exhaust Manifold Torque Spec
Car: 1984 Trans AM
Transmission: 700-4r
1984 305 ci engine in my T/A
Checking the service manual engines section, I see a spec for these stock manifolds of 75 lb.ft.but under the 350 diesel specs section. This seems excessive. Is
75 lb.ft.correct?
75 lb.ft.correct?
Transmission: T-5, TH350, T-5
Re: Exhaust Manifold Torque Spec
A 3/8 bolt is probably going to snap before that. Torque for a bolt that size is around 30. 25-30 is fine.
