1991 Trans am starting problems
Old May 23, 2022 | 02:36 AM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
My 1991 GTA 5.0 tpi car would not start. However unplugging the cooling sensor and then the car would start but immediately cut out after firing up.
So i replaced the temperature sensor but the same problems persists. Any idea on whats causing this. Is the pigtail bad, another sensor?
Old May 23, 2022 | 11:59 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1991 Trans am starting problems
Any codes for cts high or low ?
Old May 23, 2022 | 12:58 PM
Engine: V8 305
no check engine codes.. the car won't start long enuf to display any
Old May 23, 2022 | 01:04 PM
Engine: Lb9
Transmission: M20
Might check basics fuel pressure and injector pulse. Unplugging the cts will increase fuel.
Old May 23, 2022 | 10:04 PM
Engine: V8 305
new fuel injectors and according to the garage the pressure is good. I'm at a loss... maybe another fuel related sensor?
jeffas000073
Oct 3, 2018 05:44 PM
robster66
May 4, 2009 11:04 PM
nathan2003
Sep 20, 2003 04:06 PM
breathment
Oct 20, 2001 05:30 AM
