Car only starts with choke fully open?
Old May 28, 2022 | 01:54 AM
HeavyChevy383's Avatar
I got a 383 stroker in my 85 z28.
The car only seems to start with the choke fully open and idles really rough. It also lacks power upon acceleration:
https://imgur.com/a/lUdeJN2
Car was backfiring through carburetor when I press the gas pedal
It was also puffing black smoke out of exhaust during high rpms (4k+)
New ngk 3035 header plugs, new ngk hei 8mm plug wires. However this poor idling was happening with old plugs/wires too.
car also diesels for like 5 seconds after turning it off. I reckon im running way too rich but dont know where to look. I tried advancing timing but no help there it still idles poorly.
This is what my carb looks like at idle: https://imgur.com/a/ZVw3rxM
It's a edelbrock 1406 carb
msd 6a 6200 ignition
Msd blaster ss coil
Msd hei distributor
Anyone know what could cause this?
Old May 28, 2022 | 07:11 AM
Vader's Avatar
Re: Car only starts with choke fully open?
Your assessment seems correct. It is probably rich. It's a carburetor, so the basic items are float level, fuel leaks, and adjustment.
Did it EVER run properly with that setup?
Old May 30, 2022 | 07:04 PM
It did run much better when i got the car, but it needed headers and a lot more work.
Old May 30, 2022 | 10:09 PM
skinny z's Avatar
Some of what you describe sounds timing related.
Have you had a timing light on it? Is TDC on the timing pointer verified?
Old May 31, 2022 | 06:11 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
-check timing with a light
-tune the carburetor(because it’s currently running pig rich)
Camaro-3
Jul 11, 2017 02:37 AM
rfox
Aug 7, 2011 02:39 PM
mrwebb40
Carburetors
Mar 11, 2009 11:41 PM
1985transmaro
Carburetors
Feb 6, 2008 09:50 PM
VanBC
Carburetors
Sep 16, 2004 08:07 PM
