quadrajet carb for 85 z28
Car: 1985 chevy camaro z28
my car caught on fire and had to replace the harness and spark plug wires. but now my carb won"t work right and my choke light always come on. just got the carb few weeks ago and it also running rich. so what could the problem be. and it hesitates when when i put my foot on the gas to accelerate. could that have something to do with the carb too
Car: '83 T/A, '83 Firebird
Engine: Carb 350SB. Carb 305SB
Transmission: 700R4. 700R4
Re: quadrajet carb for 85 z28
Well sounds like the carb is not working properly. I would try adjusting it and getting it to a happy middle ground where it runs good. Does it have a ton of miles on it might be ready for a rebuild or a new one bud.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Make sure the choke wire is providing 12volt to the choke housing when the engine is running. It pulls power from the alt so that the choke coil isn't heated with the ignition on/engine off. Make sure the choke blade is slowly opening after started. Should take a few minutes for it to open to 90 degrees straight up.
Improper choke action could cause all your symptoms.
How was the choke acting when you checked? Open 90 degrees straight up when fully warm?
Car: 88 GTA "Cocaine"
Engine: 350 tpi
if you warm the car up to operating temp go to the pass side of the carb and there is a green lever behind the choke assembly
move that up and down
when the car is cold there should be some spring tension on it
when it is cold there should not be any tension
well my temp gauge isn't working so how will i know and what could be the problem with the temp gauge not working thanks
Most likely cause of temp guage failure is loosing the connection between the sender wire and the temp sensor. Check the guage sensor located on the drivers head between #1 and #3. Should have a spade terminal connector for a single wire guage feed. Reconnect if loose. Replace the wire if missing.
Your choke coil should slowly open the choke blade while the engine is running. Should take a couple minutes. If you've found the choke wire you can temporarily disconnect it and check it for 12 volts WITH the engine RUNNING.
fixed the carb now its black smoke is coming out exhuast . does that mean the motor needs to be rebuilt. cause the car has been sitting for a while off and on for the two years since i bought it and four years before that
GVMV
08-16-2015 08:01 PM
