Valve Rotator Elimination
Old Jun 2, 2022 | 01:47 AM
Locherle's Avatar
Hey all,
i am in Process with my first build. 305 TBI.
I installed a Comp Cam Kit K08-500-8. The Kit included Valve Springs with higher Valve Pressure.
My Questions is, will the Valve Rotators handle the 105lbs Spring Pressure or should i Install Valve Rotator Eliminator Shims.
I am a little afraid not using the Rotators and getting burned Valves. I am also afraid using the Rotators and they will bust.
The Car will be driven, mostly Weekends, but longer Times on Highways.
What do you think?
Old Jun 2, 2022 | 09:46 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Valve Rotator Elimination
it's common to delete them and install shims
Old Jun 3, 2022 | 10:55 PM
BOOT77's Avatar
Vortec engines don't have them.
Locherle
May 16, 2021 02:37 PM
built91Z28
Sep 5, 2010 11:22 AM
keeslinger31
May 12, 2008 10:12 PM
Z28z
Feb 13, 2004 06:23 PM
JPiroc87
Jun 10, 2003 12:06 PM
