1986 trans am egr soelnoid
Old Jun 5, 2022 | 06:22 PM
keithl1967's Avatar
It appears the TPI solenoid for 85-86 is "obsolete" and no longer made by OEM or aftermarket.
I have a brand new AC delco solenoid that I purchased form Eckler's (they had it labelled as 85-92, but is not the same as the original on the car.
Can the later 88-92 solenoid be used on the 86 (if I fab up a proper bracket for it)?
The connector loos to be the same (just rear-facing instead of forward facing), and it hs two ports for vacuum, that are forward facing (like the original).
Old Jun 6, 2022 | 06:49 AM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Re: 1986 trans am egr soelnoid
Short answer is yes. You can use it.
adelane
Jul 9, 2024 07:21 AM
1989IROCTPI
Carburetors
Aug 27, 2021 06:46 PM
TylerSteez
Feb 28, 2017 06:33 PM
86Tra/maro
Jul 4, 2001 11:42 AM
