This is the work I undertook/completed today
Car: 1984 Trans AM
Transmission: 700-4r
Since the thermostat housing was leaking I refreshed the old housing (cleaned & painted), replaced the thermostat with a 180*,+ new gasket &sealant .
I also replaced the temperature sender & now the temp gauge appears to be more accurate.
I also replaced the preformed heater hose with the same style hose.
All is reassembled, car road tested & all appears wel.
Engine: 5.7 L98
Re: This is the work I undertook/completed today
The 180 T stat was a great choice, it really helped my TPI car run cooler along with a new tune. I think these cars ran too hot from the factory and running cooler will make the car feel stronger IMO.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Yeah, the 195° thermostat is for emissions (higher temp = more complete burn). The 180° won't make your engine run at 180°, but it will run cooler if the cooling system is up to the task, and if the ambient temperature is not too insanely hot...
Car: 1984 Trans AM
A 180* tstat begins to open at 180 but not fully open until 190-195*. The '72 Buick GS orig factory tstat was a 195 but most owners of that ear replaced with 180* tstat.
killer305
Dec 22, 2001 03:24 PM
