Hood Seal
Old Jan 19, 2002 | 06:07 PM
Buck268's Avatar
Hood Seal
If I was to remove the rubber seal on the back of my hood, i know water could get in, but would it under normal conditions? Wouould it be a problem, or would it just drain away. I ask because my engine runs hot. Really hot. fan dont turn on till like 240*. I plan on putting a 200* fan switch in w/ a 180* thermo soon, but if removing the hood seal wouldnt create a problem, i would like the hot air to have a place to leave. Thanx
Old Jan 19, 2002 | 06:38 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I can't answer you question about water, but can tell you that removing it will have no effect on coolant temps.
Old Jan 19, 2002 | 07:21 PM
85 Berl's Avatar
I didn't have a seal for the hood, and water used to drip on my dist. Can't say for sure on yours, though. I dont' think it'll have much effect at idle. It may help some once you get going.
Old Jan 19, 2002 | 09:53 PM
Buck268's Avatar
Well, I wouldnt expect coolant temp to go down any amount, but I would expect it to help accessories extend thier life, and if there was no neg. side effects, its real easy and all.... Just was wondering. Although I would rather NOT learn the hard way why GM put that seal there...
Old Jan 19, 2002 | 10:04 PM
Enkil's Avatar
Before doing that, I'd figure out why your engine was running so hot.
Old Jan 19, 2002 | 10:56 PM
Hulk0202's Avatar
The amount of turbulance in the area of the seal is great, so removing it will cause a little more air, cool air, to flow through the compartment. Its not going to help you though. I have mine removed for a diffrent reason. Its been gone for over a year. I live in Florida with huge thunderstorms, and I've never had a problem.
Old Jan 19, 2002 | 11:20 PM
TBI305Camaro's Avatar
i took mine out and its rained, snowed, and everything else with no problems
Old Jan 19, 2002 | 11:45 PM
Xenodrgn's Avatar
Mine is gone also, and I also have no problems...
Old Jan 19, 2002 | 11:46 PM
Buck268's Avatar
Well, I know why its running hot (Sorta). My fan dont come on till it gets to 240*-250* now, ui beleive thats the back-up fan run by some sorta thermostat switch unit. I beleive also that the ECM should turn on the fan when it reachs 228* (or something close ot that). I beleive that the ECM is not getting a good temp reading. I think its only getting an intermittent signal from the CTS b/c after a good while (maybe 15min?) of driving the SES light comes on, and its a code 15. I have the AC delco replacement fer the CTS plug, theres a brand new CTS in there. I think I bend the receptors in the plug when I jumpered it out to tect the wiring. Basically, I gotta find time to splice in the new plug...then I shall see what my problem is.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
blackandblue02
Sep 10, 2015 08:19 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
