Multiple misfires
Old Jul 28, 2022 | 10:01 AM
3rdgenkindagal's Avatar
Car: 92 RS
Engine: V8 5L 305
Transmission: standard rebuild w/ corv servo
Multiple misfires
92 Tbi v8 5l. Having an intermittent misfire issue, is progressively getting worse, no white smoke out of tail pipes not sure if it's heads.
Replaced ignition module, ignition coil, cap, plugs, rotor, going to replace wires.
When we removed the cap and rotor we noticed what looks like a gear in a housing that I think holds the pickup coil. Entire thing is rusted to hell, will replace whole distributor. Any other ideas?
Also if it is the head gaskets what's the labor on that if I do it myself and hours it should take someone else if I have them do it. I haven't had a vehicle for months been borrowing mom's trying to get this running.
Old Jul 28, 2022 | 12:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Multiple misfires
Considering the distributor, if it's never been replaced, is now 30 years old. They do wear out. Replace that first.
Old Jul 28, 2022 | 01:22 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Certainly do the wires first. A worn out distributor can cause misfires though.
Old Jul 28, 2022 | 04:31 PM
Car: 92 RS
Engine: V8 5L 305
Aight, so wires and distributor for sure.
Old Aug 4, 2022 | 02:49 PM
Car: 92 RS
Engine: V8 5L 305
This misfire is so odd. It is intermittent. Sometimes on one cylinder sometimes the whole car, the other day it didn't misfire at all. XD
Old Aug 5, 2022 | 11:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Worn out bushing in the distributor shaft?
Drac0nic
May 29, 2020 11:41 PM
bravepride70
Jan 18, 2010 06:14 AM
necros9828
Aug 14, 2007 08:06 AM
Xenodrgn
Aug 5, 2001 08:25 PM
nelliesIroc
Dec 5, 2000 05:46 PM
