How to find the right AC Delco plug for my heads
Old Sep 4, 2022 | 10:46 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
I recently posted pictures of my plugs & asked for some advice. Though they look okay, I've decided to swap them out over the winter and change from NGK to AC Delco.
The problem I'm having is, that I'm not sure which AC Delco plugs are the correct ones. The instructions that came with the Edlebrock heads list Champion RC12YC plugs for street applications, so I cross-referenced that to NGK and came up with BK5RE. That was easy, but when I try to cross reference either to AC Delco, I get a list of different plugs and I'm not sure which one is the same heat range.
Old Sep 8, 2022 | 07:29 AM
Vader's Avatar
Re: How to find the right AC Delco plug for my heads
Did you happen to see this thread from a while back?
https://www.thirdgen.org/forums/tech...ml#post3379970
Old Sep 8, 2022 | 08:25 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
C4 corvette uses the FR3LS or FR5LS and it's what I use. I still have some old stock that I use so not sure what the numbers are these days
Old Sep 8, 2022 | 10:18 PM
ULTM8Z's Avatar
Been using Delco Rapid Fire 5's the last several years. They're good plugs. Basically equivalent heat range to FR5LS.
bensbaby
Jul 8, 2022 04:33 PM
kretos
Jan 20, 2004 02:22 PM
89IRO
Oct 23, 2003 11:26 PM
tony1784
Sep 18, 2003 01:54 PM
vortech305
Oct 27, 2002 08:01 AM
