Lets talk plugs
Old Jan 7, 2004 | 02:06 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
Lets talk plugs
what kinda plugs do you fellow thirdgen's use? i've got ac delco rapidfires
Old Jan 7, 2004 | 02:44 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
the cheapest ones Advance Carries, i think they are autolites.
Anyways, spark plugs dont really make any difference at all, unless you have like really high compression or boost.
Old Jan 7, 2004 | 02:54 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i found with the ac delco's i'm getting a bit better milage
Old Jan 7, 2004 | 03:49 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
AC Rapid fires all the way. All my GM cars run are rapid fires. its worth the 3.99 a plug.
Old Jan 7, 2004 | 03:55 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
hell yeah
Old Jan 7, 2004 | 05:24 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Using bosch 4+, work fine for me, i've heard complaints about these, been on for about 700 miles now and still runs good, I didn't see any difference like they say, I wish I would have gone with some cheaper ones .
Old Jan 7, 2004 | 05:34 PM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
i use ngk v power's
Old Jan 7, 2004 | 05:40 PM
FAST RS's Avatar
i READ AN ARTICLE ABOUT THE +4'S AND THEY SAID THAT THE SPARK WILL GO TO THE CLOSEST GROUND AND THE OTHER 3 PRAWNS WOULD GET A SLIGHT SPARK. THEY SHOWED A PICTURE OF IT TO. I say NGK and Denso plugs are good for imports im not a fan of bosh. Motocraft with ford etc AC with GM thats just how i feel. I also like the Champion Truck Plug i put that in my friends Jeep runs great with them.
Old Jan 7, 2004 | 05:51 PM
gm uses both ngk and denso at the factory. i have a brand new ls1 with denso's and i have seen ngk's used in 3800's.
Old Jan 7, 2004 | 05:53 PM
Luder[PAK9]'s Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 MPFI
regular acdelcos
Old Jan 7, 2004 | 06:04 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
seems like everyone i know or talk to who owns a chevy uses ac delco rapidfires all hondas use bosch platinums +4 and fords i dunno
Old Jan 7, 2004 | 06:11 PM
FAST RS's Avatar
werid all the gm cars we have ever owned had AC plugs in them
Old Jan 7, 2004 | 06:33 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
can't argue with quality
Old Jan 7, 2004 | 07:41 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Whatever works usually
Right now I'm using some inexpensive Bosch Platinums, a buck a plug, lifetime warranty....I like that.
Old Jan 7, 2004 | 10:12 PM
IROC-Z2814's Avatar
running NGK v-powers in my 2.8 and it runs better since I changed the plugs from some crap my dad had put in before
Old Jan 7, 2004 | 10:16 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
you like the NGK's? i haven't heard much about them
Old Jan 8, 2004 | 02:33 AM
IROC-Z2814's Avatar
I know Schucks, Knechts and a couple other auto part stores in that chain should sell them. I also found them at Napa but they had to "special order" them for me. I think they're a pretty good plug. I also run them in my 1988 IROC 350TPI and in my 1979 Subaru 4WD wagon. I haven't had a problem with them yet and it also seemed to give my v6 Camaro a little more power
Old Jan 8, 2004 | 10:35 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well that's the same thing with Splitfires. Electricity ALWAYS takes the shortest path. In fact, Splitfire never claimed the spark would "split"! The point of a splitfire (and I believe the Bosch +4's) is that more of the "spark" is exposed to the a/f mix, without being covered up by a thick electrode.
Plus, with 2 or 4 points, theoretically, when one point wears down, the spark will use the other points- the plug should last longer.
As for me, I ran splitfires for years, since '94... when I got the msd box in 2000, the center electrode started wearing away FAST. So I switched to AC/Delco R45TS's- and they have the same problem. Oh well.
Old Jan 8, 2004 | 11:00 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I currently run standard acdelcos in mine.
In my s10 enigne, I ran champion truck plugs. Ran nicely up front, wore off fast, and like crap.
Then went to acdelco rapid fires. Did same thing, but lasted tad longer.
standard ones run not as good up front, but last 4x as long.
New engine, I'm going to try some halos.
Old Jan 8, 2004 | 12:27 PM
FAST RS's Avatar
I have a MSD 6AL and MSD Coil All i have ran are the rapid fires with it and have had no problems. Even tho they are platnum and they say not to use plat i have never had any problem and i have had my MSD for about 4 years as well.
Old Jan 8, 2004 | 12:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks for the tip!
Old Jan 8, 2004 | 12:47 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Accel coil and plugs.
Kem wires.
Any cap n rotor with the brass/gold parts.
Accel 8190
Spark Plug: U-Groove; 6 Pack
Old Jan 8, 2004 | 01:01 PM
FAST RS's Avatar
I run the MSD wires and brass cap and rotor from autozone. Only problem i ever have is my number 3 wire melts because of where the egr is on the car its a 3.1 the msdwires are the only ones that hold up all the other ones melted apart. I sent msd my wire set back because that wire melted and they sent me a new set free of charge.
Old Jan 11, 2004 | 11:34 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
well for the v6 i have the ac's helped the power a bit
Old Jan 11, 2004 | 11:57 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Yeah, it's true. All the standard plugs are Delco but most of the platinum and iridium plugs are NGK or Denso. They come in a Delco box and even say ACDelco on the porcelain but if you look closely it'll say NGK or Denso on the metal part.
Old Jan 12, 2004 | 01:31 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
hmm might have to look into this one but hey i bought the plugs and they work great for me
Old Jan 14, 2004 | 09:28 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Rapid fires all the way for me as well
smother idle and more top end.
Old Jan 14, 2004 | 09:52 AM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I had AC Rapidfire plugs but then once they were in for about 30k I replaced them with the AC Professional Platinum plugs which seem to run about the same as the Rapidfire in my own opinion. I've kept track of my gas mileage and other various things for 3 years in an excel spreadsheet. I have not noticed much difference in gas mileage from one set of plugs to the other.
Old Jan 20, 2004 | 02:22 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
It might have been this board or the v8 board where a guy was using split fire plugs and MSD box 6a.
The guy said the results were scary w/ dual flame fronts and the spark wasn't jumping to the split, but rather to the stem before the bend and had almost burned it off.
TomP is 100% right electricity finds the shortest path.
Good old Delco for me. But always check the gap even though they come pre gaped, I've found some that where to close.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
TrevinE
Sep 14, 2015 03:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Jlanz55
Sep 9, 2015 09:09 AM
