Anyone running regular AC delco plugs on their TPI?
Old Oct 18, 2002 | 04:34 PM
vortech305's Avatar
The store closes in an hour and half, and i need to know which plugs i should go with? As of now i have AC Delco RAPIDFIRES and im not too pleased with them, So im not sure whether i should get Regular AC delco plugs. The motor is an 87' 305 TPI w/ L98 alluminum Vette Heads. From what i heard i wont touch Bosch, So i hear AC Delco or NGK, If so anyone know what heat/cold range i should go?
Old Oct 18, 2002 | 04:46 PM
89BlueTA's Avatar
This might be too late, but I like both the regular delco plugs and the NGK's. Right now I am running the NGK's.
nick
Old Oct 18, 2002 | 04:58 PM
vortech305's Avatar
how is the NGK's? Why type
Old Oct 18, 2002 | 05:19 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I'm running regular OEM-spec Delco plugs. Runs a whole lot better with them than the Bosch Plats I had.
Old Oct 18, 2002 | 11:23 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
You'll probably notice your idle inprove after ditching those Rapidfire's I've had nothing but problems with them.
Old Oct 19, 2002 | 08:26 AM
Morley's Avatar
I liked my rapid fires when I had them, the car really seemed to like them too.
AC Delco plugs are the way to go, I have tried several different mfg plugs and always came back to Delco, they just plain work better in my car.
Old Oct 19, 2002 | 09:56 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I'm probably too late, but i normally run AC R43TS in about everything.
I'm running the accel shorty plugs that cross reference to that right now though, much easier with the SLP headers.
Old Oct 26, 2002 | 01:28 PM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
i have to agree with Ed i run the AC43TS and they seem to run good.
Old Oct 27, 2002 | 08:01 AM
Vader's Avatar
Champion RV15YC4 works great for me, but I'm running mostly stock engines with nothing over 11:1 compression.
sailtexas186548
Jan 19, 2016 12:21 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
