my plugs too hot? engine knock Autolite 3924
Old Sep 11, 2022 | 03:07 PM
m300slr's Avatar
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
Hey, I have a new motor and I am trying to figure out some ping/knock issues. not sure if they are real or false. I have driven the car about 150 mi ish.. the plugs look ok I dont see any evidence of detonation but maybe its too early. I am wondering if the "stock" plug that brodix recommends is too hot for my application. The plug is a Autolite 3924. I wonder if I should go with a set of 3923's.
I am running a 355 with Brodix IK 180 heads .500 lift cam 224/224 10.2:1 ish compression and 8.3-8.4 dynamic TPI intake, ported edelbrock manifold with AS&M tubes 52mm throttle and shorty headers.
Old Sep 11, 2022 | 07:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: my plugs too hot? engine knock Autolite 3924
Plugs only need to be hot enough to burn the deposits off the plug. Too hot and they may start to melt the plugs. Too cold and they foul up. There is no right or wrong answer as to what heat range the plugs for your engine requires.
Plugs are cheap. Run the coldest plug possible that doesn't foul up.
A good heat range will have a temperature change line about half way up the ground strap.
Old Sep 11, 2022 | 08:28 PM
m300slr's Avatar
Car: 1985 Z28
Thanks for the reply. Im attaching a pic of the plug. Looks pertty good I suppose, but only has 150 mi ish.. I can see the temp change you refer to in the photo. I may still try the 1 step colder plugs. But now I need to determin what may be causing my knock, or causing false knock.
Old Sep 11, 2022 | 10:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Temp line could be a little higher but it's close. One heat range colder should work.
Gen X T/A
Dec 9, 2022 11:59 AM
jeffas000073
Oct 23, 2018 12:12 PM
torqueaddict
Aug 8, 2009 12:23 PM
91wtROH17's
Sep 10, 2003 06:50 AM
steve8586iroc
Aug 17, 2001 07:26 AM
