Total Seal Gapless Gasported piston rings
Old Nov 8, 2022 | 05:16 PM
Tombowman89's Avatar
Car: 88 Iroc
Engine: 388 Vortec Pro-Flo 4 Small Block
Axle/Gears: 3.77 to 1
I’m installing the new gapless gasported piston rings.
My engine is a 388 SBC flattop pistons with some other cool stuff, I won’t bore you with details unless you ask. They are currently about 600 bucks, a lot of benefits in running these. On the quest to go fast.
Old Jul 12, 2023 | 07:50 AM
Car: 88 Iroc
Re: Total Seal Gapless Gasported piston rings
Made excellent power at the dyno, good leak down cylinder numbers, compression numbers and with a .550” lift, 190cc runners and 220 duration it made 450 hp and tq. Given the camshaft was a kitty cam. Throw more duration in that cam and it’s pretty impressive how well a motor with kick *** rings will do
Old Jul 12, 2023 | 02:47 PM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
What heads are you using?
Old Jul 12, 2023 | 03:46 PM
Car: 88 Iroc
I used a set of AFR 912’s, they are a Vortec AL head Basically. Just stay tuned though the next engine will be a screamin 355. Not your average small block, I may start a YouTube channel showing some very intriguing and informative engine builds using new technology etc etc.
giszo
Feb 2, 2011 12:35 AM
doc
Jul 3, 2009 12:19 PM
riberware
Jan 22, 2009 07:46 PM
86Tra/maro
May 14, 2002 08:31 AM
