4th Gen LT1, does the cam have a distributor drive gear?
Old Nov 15, 2022 | 07:44 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I’ve come across carburetor conversions on the LT1, but the distributor drive gear thing is fuzzy on my Google searches.
Thanks.
Old Nov 15, 2022 | 07:49 AM
Vader's Avatar
Re: 4th Gen LT1, does the cam have a distributor drive gear?
The 1993-1997 LT1/LT4 engines have a gear on the camshaft to drive the distributor/oil pump. The factory LT1/LT4 used a distributor mounted to the front of the engine instead of atop the intake. There was a stub shaft with housing bolted into the lifter valley which had the driven gear to operate the oil pump.
Old Nov 15, 2022 | 07:56 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
how ya been old man? This engine is in a ‘97, so should be able to run a conventional distributor?
Old Nov 15, 2022 | 07:18 PM
Vader's Avatar
If you get an intake that will support the distributor, it would be just like old times.
woody80z28
Aug 4, 2011 03:18 PM
vasquezmrysvll
Apr 21, 2010 07:52 AM
kkingsrulee
Jan 10, 2009 07:41 AM
89lt1
Apr 27, 2008 06:28 PM
1986redbird
Jun 19, 2003 11:32 PM
