Firing order swap cam kit?
Car: 1987 Iroc Z
Engine: L98 350 tpi, passenger side alt.
Axle/Gears: 3.23 LSD
Hey guys, i was playing with the idea of doing a
4-7/3-2 firing order swap on my l98 and havent been able to find any out-of-the-box cam kits to do this. There are 4/7 swap kits, but i havent found one that does the 3/2 as well, as of yet anyways.
2 questions:
Does anyone have a source for a kit that would perform the full LS firing order swap, or would i need to re-grind a/my cam for this?
I’m assuming i would need to remap the ecu for my stock TPI, for fuel to be injected at the proper times. Or buy a new ECU. is this correct, and if so, which is more worthwhile?
thanks in advance
2 questions:
thanks in advance
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Firing order swap cam kit?
Why? Firing order swap only helps with a single plane intake and a carb.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Ls firing order would need new cam core. Only few sources for cores and they can be hard to find/get these days. To benefit from it you need full sequential efi
ls firing order is suppose to be smoother and easier on the main bearings. Not that conventional has any issue with a sbc anyway but there was a reason why gm did it
Sounds like a custom grind deal http://jonescams.com/
Isn't the stock TPI a batch fire for injectors like side to side?
Car: 1983 G20 Chevy
Transmission: 4L60
Head gasket survival, that has to be trivial. The only place I have seen them blow is between 3&5 as well as 4&6 when they are overheated.
Funny, I went back to the traditional firing order on my 8.1L. I think the traditional firing order sounds better than the LS PUKE one myself. That is just me though. Also since I typically run Tri-Ys they are built for the old firing order.
Far as headgaskets some would argue 5,7 is a hot spot, maybe more so with power adders....
1, 8, 4, 3, 6, 5, 7, 2
My point is there is more than one reason often to a mod and not everyone can benefit from them. I honestly wouldn't bother with a firing order swap sub 400 fylwheel hp But those who need that fraction of an advantage. Well that's what many of the mods that some say "do nothing" or "are a waste of time" where they shine.
Car: 89 Iroc-z
Transmission: TH400
https://www.enginelabs.com/engine-te...r-your-engine/
all you need to know really
The LS firing order is easier on the crank. It doesn't solve the problems of the 90deg crank, it just moves them around. You still have both cylinders on 3 of the 4 throws firing back to back, but with the LS firing order, it moves this to the rear 3 throws, away from the weaker front throw.
Car: 1987 Iroc Z
Well preference is one thing & Custom parts compatibility is well...
Also; i personally enjoy the sound of LS motors, and think it would be pretty rad to have an 80’s sbc sound similar!
Car: 1987 Iroc Z
i was looking into comp as well because i know they do custom grinds, but i’m gonna have to wait a couple weeks due to trouble with my beater
Car: 1987 Iroc Z
Bump because ive been doing some more thinking about this and something is bugging me.
would i need a new crankshaft as well? As it stands; by swapping the 4-3 and the 7-2, wouldnt that mean the 7-2 cylinders would be firing while the piston is bottomed out?
dont the outer pistons come up at the same time and alternate with the inner 2?
i’ll use an i4 setup as an example for my question:
would cyl. 1/4 be reaching tdc while 2/3 are bottomed out, or would 1/3 be at tdc while 2/4 reach the bottom?
No the crankshaft stays the same, you are simply swapping around the valve events of the cylinders and the ignition sequence. this is pretty much a waste of time, in my opinion on something running a very small duration/lift. you may not notice much of a sound difference even. this will be a custom billet cam, and will be expensive, since nobody typically is going to do a 4/7 swap on a low rpm small cube TPI setup. You would also need to figure out the distributor gear situation... would need to be compatible.
as mentioned above, gm did it to even out the stress on the crankshaft. engine masters proved there was no real power to be found with the swap.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: firing order swap:
You must have a LOT of money to waste.❗️
