Fel pro 1094 steel gasket
Old Feb 7, 2023 | 08:59 PM
19z's Avatar
19z
I decided to give a fel pro 1094 steel head gasket a shot. On the 2 nd pass I heard a pop, it felt like something gave, hard to describe. Anyone else have this experience? Normal? It only did it one side.
Old Feb 7, 2023 | 09:02 PM
Re: Fel pro 1094 steel gasket
About every one I ever used. Especially if block/head prep wasn't PERFECT.
Just not my idea of ideal.
Eeeeezy enough to troubleshoot with a compression test though; usually you'll have 2 adjacent cyls with low compression, most often the center 2 on one side.
Old Feb 7, 2023 | 09:19 PM
19z's Avatar
19z
Had the block and heads surfaced, still on the stand, no wiring or starter. I’m thinking now would be the time if I need to change them.
Old Feb 7, 2023 | 09:41 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The engine backfired or the exhaust poped.
Fuwl explosion in exhaiust system
Whats that got to do with a head gasket?
If you are running it on a stand. likley incorrect ignition timing.
Old Feb 7, 2023 | 09:47 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Sounds like he was on the 2nd pass torquing the head down. Hopefully it was not a dowl pin that was not aligned correctly.
Old Feb 8, 2023 | 01:49 AM
F-BIRD'88's Avatar
Maybe you left a Cherrios on the piston when you put the cylinder head on.
Or, a Fruity Pebbles.🤗
Old Feb 8, 2023 | 09:08 AM
19z's Avatar
19z
Sorry I wasn’t very clear, yes it was when I was torking down the head gasket. It was sitting down flat, the dowels lined up. It just felt like something gave, never used a steel shim before always a mls or composite.
Old Feb 8, 2023 | 09:42 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Sure it was not the head bolt that gave?
Old Feb 8, 2023 | 11:59 AM
F-BIRD'88's Avatar
Or the socket cracked.
Old Feb 8, 2023 | 06:07 PM
19z's Avatar
19z
Socket looked good, used new arp bolts. They torked down to final specs fine. I think I’ll get a new intake gasket and head gaskets before I put it back in. It’s going to be easier now rather than later. Just thought it odd, never had that happen with regular head gasket.
Old Feb 8, 2023 | 08:14 PM
F-BIRD'88's Avatar
Never have I had a problem with the shim head gaskets.
Old Feb 9, 2023 | 01:48 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have not either. They usually crush when I run the head bolts down with my speed wrench. Does not take much force to bend the ridges straight when you have 17 head bolts.
Old Feb 9, 2023 | 03:45 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Kinda' funny, but I read 'On the 2 nd pass I heard a pop', as WOT on the strip.
But if it was during head torquing, ether a bolt broke or the block threads pulled out...
RBob.
K88-79
Mar 1, 2011 11:55 AM
zach92rs
Jun 29, 2008 07:06 AM
xyzman
Feb 13, 2008 08:30 PM
rover420
Nov 27, 2006 04:56 PM
SLEEPER 86
Feb 3, 2006 10:05 AM
