355 Compression Question
Old Feb 13, 2008 | 08:00 AM
xyzman's Avatar
Can someone tell me what my compression ratio will be with +30 4 valve relief flat top pistons and a 64 cc head the piston is sitting about 20 thou down in the hole from TDC thanks
Old Feb 13, 2008 | 08:34 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: 355 Compression Question
I don't know the math (well, I did, but forgot it) but I know that whoever computes this will also need the thickness of your head gasket.
Old Feb 13, 2008 | 09:26 AM
SteelTownMadDog's Avatar
Assuming a 4.1" bore/.038" thick head gasket, around 9.7:1.
Old Feb 13, 2008 | 09:52 AM
Damon's Avatar
Wiith a typical Fel Pro .039" composite head gasket (blue rebuilder head gasket) you'd be at 9.75:1.
With a thinner GMPP .028" composite head gasket you'd be just shy of 10:1.
With a real thin .018 steel shim head gasket you'd be at 10.3:1.
Old Feb 13, 2008 | 09:56 AM
xyzman's Avatar
Thank you all xyZMan
Old Feb 13, 2008 | 11:33 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's assuming zero deck height, which is rarely the case with rebuilder pistons.
Old Feb 13, 2008 | 08:24 PM
Damon's Avatar
He said they were sitting 20 in the hole, so that's what I calculated on.
Old Feb 13, 2008 | 08:30 PM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
Check out this online CR calculator http://www.csgnetwork.com/compcalc.html
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
355tpipickup
Aug 13, 2015 07:35 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
