Chevy 350 Block ID
Old Feb 14, 2023 | 08:42 AM
hwilkinson's Avatar
Chevy 350 Block ID
I have a Chevy 350 5.7L 880 in a Jeep CJ7 and cannot get my eyes or camera on the block numbers however I can see that it was made in Mexico and “1M0523 5ZZ4” is stamped where you would typically find the ID Code or VIN and “6463 188” and “MY0405 2” is stamped on the Driver’s side rear, facing backwards. See the attached photos for reference.
I am hoping someone can help me understand and identify this block.
Thanks in advance!
Old Feb 14, 2023 | 08:49 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Chevy 350 Block ID
What’s the head casting number under the valve cover ? 113 ?
Old Feb 14, 2023 | 08:53 AM
hwilkinson's Avatar
TP,
Those are the only visible numbers. Should I remove the valve covers to find another number?
Old Feb 14, 2023 | 09:00 AM
Engine: Lb9
Transmission: M20
They’re visible once the valve cover is off. I’m thinking there aluminum heads and you have a gm zz4 crate engine. The head numbers will tell you what they came on.
I thought the zz3 & zz4 were not Mexican made but could be wrong.
Old Feb 14, 2023 | 11:54 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
They are definitely Mexican 880 blocks. GM shifted the production of the 350s all to Mexico because Mexico and South America was still getting them in trucks through about 2007.
Judging by the aluminum pocking out of the accessory holes and the ZZ4 stamp. My best guess is that is a legitimate ZZ4. The other number with that one is some form of serial number stamped into it.
Old Feb 16, 2023 | 09:07 AM
hwilkinson's Avatar
I was able to get some photos of the casting numbers by using my Go Pro camera mounted on a tripod. Looks like a 10243880 but I can't figure out the "2" and the "05" above "Hecho en Mexico" or the "I34" near the shift dial stamp. Thank you all in advance for your assistance.
See below and let me know your thoughts:
Old Feb 16, 2023 | 08:30 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Looks like someone who has seen several ZZ4s reported that every ZZ4 he saw had ZZ4 stamped in the front on the suffix pad. Looks like all the ZZ engines from ZZ0 on had the numbers stamped.
How to verify it's a ZZ4? - CorvetteForum - Chevrolet Corvette Forum Discussion
How can I verify a ZZ4?? | Team Camaro Tech (camaros.net)
Old Feb 16, 2023 | 08:41 PM
hwilkinson's Avatar
So one follow up question. The seller claimed this was a "359"ci but couldnt explain any further, he had inherited the vehicle from his father when he passed away and was only second hand info. I can't seem to find any info on a "359" other than assume it has been bored and stroked for larger pistons??? Any thoughts and thanks again in advance.
DontBlnkBadWolf
Aug 17, 2022 10:32 PM
Jmazz97
Apr 21, 2022 09:25 PM
Jonnydepp
May 8, 2020 04:56 PM
J0hn_J0hn08
Aug 10, 2011 08:38 PM
ray1989
May 9, 2011 09:51 PM
