Here's a 3.8l 02 camaro doozy
Old Mar 11, 2023 | 04:29 PM
Killerbud0420's Avatar
Ok so I have a 02 camaro. Crank no start. Security is working as should. Fuel pump is kicking on and off as the throttle body clicks and the fuel pump relay. All this happens at once and the service engine soon light flashs twice. I'm getting spark. But my injectors are not spraying. They are getting power but no ground flashs. I have no clue iv checked all the grounds and everything.
Old Mar 11, 2023 | 05:33 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Here's a 3.8l 02 camaro doozy
Hi Killerbud0420,
I'm sorry to say, but, your 2002 Camaro is beyond the scope of this board. Here we only do 1982 through 1992 Camaro / Firebird (The third gen F body). Our cars (82/92) are "OBD1" where we can command the ECM to flash out trouble codes using the service engine soon light. Your 2002, however, is "OBD2" , for which you'll need to hook up a "code reader" to the OBD2 port to see if any codes relating to your problem exist. Not trying to blow you off here, but I believe you'll be far better served at a fourth gen Camaro board.
Old Mar 12, 2023 | 02:22 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Someone probably gave it way too much marijuana. It makes cars act stupid like that.
Grandlaker
Jul 12, 2015 01:25 PM
blueknight432
May 27, 2013 02:26 AM
pinky101
May 31, 2012 01:08 PM
89camaro350tpi
Jul 25, 2009 04:33 PM
