L98 engine rattle
Old Jan 21, 2002 | 08:00 AM
elhosel1's Avatar
L98 engine rattle
i just purchased a 1990 iroc with a 5.7 L98 there is a bad rattle in the lower end at start up and a big puff of smoke follows it has 111000 miles on it also the oil presure seems a bit low any help or should i look for a crate motor if so what kind will bolt right up without any computer mods
thanks
russ
also if you know someone in tampa fl who can do the work let me know
Old Jan 21, 2002 | 02:15 PM
sleeper's Avatar
What color is the puff of smoke? Black is fuel... white is coolant... blue is oil. This is very important.
What is your oil pressure? A stock pump will be around 5 to 10PSI at idle, when cold.
Old Jan 21, 2002 | 03:10 PM
elhosel1's Avatar
THE SMOKE IS BLUE, BUT THE RATTLE IS WHAT IS CONCERNING ME
Old Jan 21, 2002 | 07:41 PM
rhuarc30's Avatar
He's asking cause the smoke and rattle could be related. Blue smoke and rattle at idle at startup to me sounds like your getting oil into the combustion chambers 'causing detonation and the blue smoke. Basically something's worn, rings, guides, seals, something, so when the engines cold it lets oil into the chamber, then when it heats up and everthing expands at different rates it closes up the clearances a bit and fixes the problem a bit. If it's really way down in your lower end, it's probably worn bearings. Either way, hate to tell you but, it looks like it's time for a rebuild or new motor buddy.
John
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 19, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
mustangman65_79
Aug 8, 2015 12:07 PM
