This important?
Old Apr 1, 2023 | 07:40 PM
Soulesshuskk's Avatar
This important?
I was in my steering column to fix my turn signals, and I put it all back together and realized I had this extra piece. Does anyone know what it's for or if it's important?
Old Apr 1, 2023 | 09:35 PM
Vader's Avatar
Re: This important?
I don't recognize that as a steering column part, or at least not from the series of column (tilt or not) used in a ThirdGen.
Is this column equipped with an air bag?
Old Apr 1, 2023 | 09:41 PM
Re: This important?
No, at least I'm pretty sure it is not. I do not have the original steering wheel, but there is nothing to indicate that it was airbag equipped. Is it possible that it could be a piece of a different system located in the steering column? Like the turn signals/ high beams/horn?
Old Apr 1, 2023 | 10:07 PM
Vader's Avatar
Re: This important?
I asked about an air bag because it resembles an early contact from one of those, but nothing within the column below the steering wheel.
Old Apr 1, 2023 | 10:24 PM
Re: This important?
Well, thank you. The car seems to steer fine without it so I won't worry too much about it.
Old Apr 2, 2023 | 03:24 AM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
Re: This important?
I recently rebuilt my steering column and I can assure you nothing in there resembles that part.
Old Apr 2, 2023 | 10:00 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: This important?
It would be nice to know exactly what year thirdgen we are working on here?
Vader makes a good point about it possibly being a contact for an airbag, but beyond that I can assure you that the non airbag column has no such part in it.
Here is a great tutorial I have used to rebuild several (non airbag) columns, scroll down to the group pic of all the parts and you'll see no such part in the photo.......
https://www.crankshaftcoalition.com/...ck_Rebuild.pdf
ChevyTycoon
Mar 8, 2020 11:05 AM
beths91camaro
Jul 18, 2019 12:28 PM
Deuce of Spades
Mar 13, 2015 10:11 AM
MN91TA
Sep 8, 2014 09:11 PM
blkfire_88
Nov 8, 2012 05:26 PM
