Stage 8
Old Apr 21, 2023 | 08:31 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Stage 8
Has anyone run Stage 8 fasteners for their headers? A search didn't return much.
I'm thinking I'd like to use a set for my 1.75" tube SLP headers to my Vortec 305 (RPO L30, Casting 059) setup. But they offer several variations for the SBC.
#8911
Thread 3/8" - 16
Head - Double Hex
Underhead Length - 3/4"
Material - Steel, Nickel Plated
Lock Washer - D
https://www.summitracing.com/parts/stg-8911
#8911A
Thread 3/8" - 16
Head - Double Hex
Underhead Length - 1"
Lock Washer - D
https://www.summitracing.com/parts/stg-8911a
#8911B
Thread 3/8" - 16
Head - 12-point
Underhead Length - 1.25"
Lock Washer - D
https://www.summitracing.com/parts/stg-8911b
#8931
Thread 3/8" - 16
Head - 12-point
Lock Washer - Teardrop
https://www.summitracing.com/parts/stg-8931
#8951
Thread 3/8" - 16
Head - Double Hex
Material - Stainless Steel
Lock Washer - D
https://www.summitracing.com/parts/stg-8951
That seems to be the complete line for SBCs.
https://www.stage8.com/gm-performanc...der-bolt-kits/
I'd like stainless. The nickel plated steel seems like something that will fail fairly quickly in a harsh environment. But there seems to be just one stainless option...the 8951. It's 1" long. Others are 3/4" or 1.25" Not sure what depth I would need.
Looking at how the anti-rotation "washers" work, I think I'd prefer the teardrop shaped one, as they offer two possible alignments for each notch (by flipping the washer over). But the stainless 8951 has a D-shaped washer.
So I'm at a bit of a loss to figure out which one might be best. Was hoping someone here had some relevant experience?
Old Apr 21, 2023 | 10:43 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Stage 8
To figure out your length needed, I'd pull a bolt out of your current setup and figure out how deep it goes into the head, then add that size to your flange thickness and washer thickness and see what's closest.
Old Apr 21, 2023 | 11:20 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
Re: Stage 8
I’m using the stainless, 12 point with the teardrops. The locking feature of the Stage 8 can’t be beat, but the E clips are a PITA to work install and I have had to do it way too many times. There are other options, but they are not as reliable as the Stage 8’s. Just my opinion on this subject. Would I use them again?, most likely because of the peace of mind that they offer.
Old Apr 22, 2023 | 09:18 AM
DynoDave43's Avatar
Re: Stage 8
The heads are off the car (well, boat in this case ) as are the headers. I'll do some measuring. Vernier caliper to the rescue!
Good to know. The stainless fastener and teardrop washer combo is not currently listed in their catalog. I'll have to give them a call. It would be nice if they could supply a kit with just what I want, but it would be nicer if the kit existed and was in Summit stock, so I can add it to my order there.
Do the SBC exhaust bolts go into the water jacket?
iroc.86
Mar 31, 2008 08:49 AM
82 Iron Duke
Oct 11, 2007 07:11 AM
Dr G
Brakes
Sep 26, 2005 11:54 PM
spedrace35
Alternative Port EFI Intakes
Jun 29, 2005 11:08 PM
long&low
Mar 20, 2002 08:28 AM
