Valve springs, retainers, & seats
Old May 6, 2023 | 02:49 PM
s&thansen's Avatar
Car: 86 z28
Engine: 1970 Chevy 355
Transmission: 700r4 stock
So I ordered all the stuff from TPIS. Super L98 cam for 87-94 hyd. Roller cam, the springs they suggest for cam, retainers, and seats. I have the stock 083 heads. Do I need to use the seats?
can I put on just the new retainers?
Or should I just use the stock oil caps and retainers?
cam can be used with 1.5 or 1.6 rockers. I have a set of 1.52 roller tips from another project I was going to use.
specs on cam
L/C 112
intake & exh @ .006 270.6
intake & exh @ .50 219.6
lift is .450 on int & exh
* spring specs
hyd. Roller valve spring 1.25” w/ damper
130lbs seat pressure @ 1.75” installed height
325lbs @ 1.200”
coil bind 1.150”
outside dia. 1.250”
inside dia. .880”
max lift .550”
I’m not an engine builder so some stuff throws me off. Just trying to learn and search when I get stuck.
Old May 6, 2023 | 02:57 PM
Re: Valve springs, retainers, & seats
Should be fine.
Old May 7, 2023 | 06:05 AM
s&thansen's Avatar
Car: 86 z28
What should be fine? Just the new retainers?
Old May 7, 2023 | 09:50 AM
Oh sorry, I thought you were asking about the springs.
I would not re-use the stock ANYTHING. Use the new 1.25" retainers and new keepers. Use the "positive" valve guide seals such as FelPro SS72527 on both int and exh. Don't bother with the O-ring or "umbrella" type "seals". Do away with the oil splash shields and "rotators". Shim the springs to get the 1.75" installed height" may take as much as .125" on the exh, maybe even more. Since your cam's lift is well under the springs' max, you can shim the installed height to slightly less - emphasis on SLIGHTLY - than the spec, to get a shade more seat pressure; maybe to as low as 1.73" but I wouldn't go any farther than that. The seats are really intended for aluminum heads, where the springs will eat into the casting; not as important for your cast-iron. Use them if they'll fit (probably won't) but if not just use shims.
Old May 8, 2023 | 06:49 PM
s&thansen's Avatar
Car: 86 z28
Thanks for the info. That’s all I needed and a direction to go in. Big help and simple understanding. Appreciate it very much.
z 28 jari
Oct 21, 2015 08:58 PM
thetaman85
Jan 18, 2013 12:45 AM
ALLTEC-Z
Jun 20, 2007 01:26 AM
SeanTimothy
Dec 19, 2003 04:07 PM
Makaveli
Dec 6, 2002 09:23 PM
