32 degrees before TDC @3000pm
Old Jun 6, 2023 | 08:21 AM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
Hi,
i have a crate 350 engine in my Camaro that the harmonic balancer does not have the measurements but the metal arrow marker. I am supposed to set the spark time at 32 degrees before TDC @3000pm.
My metal tab only reaches to 12 degrees. How do I measure to 32 degrees?
Thank you in advance for any advice.
Old Jun 6, 2023 | 08:55 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: 32 degrees before TDC @3000pm
Use a dial-back timing light...
Old Jun 6, 2023 | 09:44 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
or timing tape
Old Jun 6, 2023 | 02:23 PM
podiatra's Avatar
Engine: 350 swap
Got it, thank you!!
Ozzy1992z28
Feb 21, 2020 08:34 AM
LostX
May 3, 2012 05:39 PM
doc
Mar 29, 2009 07:49 AM
paulmoore
Mar 20, 2005 07:43 PM
B CORNELIUS
Oct 26, 2000 12:26 PM
