Starting problem
Starting problem
I was having problems with my 92Z 28 Camaro, it was struggling to start 92Z 28 Camaro, it was struggling to start, and when it would start it would be rough for awhile and increase to a normal idle, it started up this morning just fine then when I turned it off the starter stayed on, I unhooked the battery and it turned off, when I hooked it back up if wouldn't start at all.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Starting problem
Have you checked basics, fuel pressure, spark and injector pulse ?
[QUOTE=Tuned Performance;6508093]Have you checked basics, fuel pressure, spark and injector pulse?
Yes I have, now the starter won't even turn on, when I turn the key it just makes a click noise and nothing happens, no rotation, nothing. (I love yalls brand, I look at your sight a lot)
Engine: Lb9
Transmission: M20
To start with the no crank, where’s the noise coming from. Kick panel drivers side or under the hood. How’s battery connections and surface voltage. You will need to do some testing to determine if it’s a starter, vats issue or wiring connection battery cables or at the starter.
