Starting issues 2.8 v6
Old Oct 15, 2020 | 04:14 PM
89camarov6's Avatar
Car: 89 camaro and 05 gmc canyon
Engine: 2.8
My car will try to start but won't.
starter does not "click" and battery is not dead,car will start up right away if I give it some starting fluid, and after I do that the car will start up right away if I shut it off and start it back up.
Any ideas what the problem is?
Car has new fuel pump and new fuel filter along with tank!
Any help is appreciated
Old Oct 17, 2020 | 06:25 PM
Mark RWC's Avatar
Re: Starting issues 2.8 v6
Have you tested your fuel pressure after the work you did? It is possible to mix up the fuel feed and return lines when reinstalling the tank. Injectors including the cold start injector are possible problems.
@SeanBert
Apr 19, 2020 12:49 PM
DaScorpio96
Apr 16, 2020 02:29 PM
Chakadog
Carburetors
Nov 7, 2019 03:33 PM
Quick-IROCZ
May 25, 2006 11:40 PM
