Pushrod length & Guide Plates????
Old Jan 21, 2002 | 08:05 PM
martyr's Avatar
Car: 88 Formula 350
Engine: 357
Transmission: 700r4 Edge 2900 Stall
Bought some aluminum corvette heads..and self aligning crane 1.5 gold roller rockers.
Do I use stock pushrods? Do I need to install pushrod guides. I have an 88 formula 350 with hyd roller cam.
Thanks for your help.
Marty
Old Jan 21, 2002 | 08:17 PM
rezinn's Avatar
You have to use stock length hardened pushrods if you install guideplants. I was under the impression all aluminum l98 heads came with guideplates and screw in studs already.
Old Jan 21, 2002 | 08:29 PM
sleeper's Avatar
what he said
Old Jan 21, 2002 | 08:33 PM
martyr's Avatar
Car: 88 Formula 350
Engine: 357
The screw in studs are there but I don't see any guide plates of course I'm assuming they mount under the screw in studs right???
Just aluminum from what I can see. About ready to remove the valve covers from my original L98 350 to see what the stock setup looks like.
Thanks for the reply!
Marty
Old Jan 22, 2002 | 07:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What you need to know about the rockers & guide plates...
https://www.thirdgen.org/techbb2/sho...threadid=77948
You do not need to change the push rods because of the rocker & head change. You meay need different ones for other reasons. If your cam is small, less than .310" lobe lift or so, your stock push rods should be OK.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
