How long will these mild steel pieces last/Worth it to get ss?
Old Jan 21, 2002 | 08:48 PM
cort351w's Avatar
No one is answering on the exhaust board. That may be because there have only been a handfull of people on there most of the day (sad, but I would know). Maybe someone can answer my non-exhaust-specific durability question:
How long can I expect mild steel **cough** exhaust pipes and mufflers **cough** to last? What about the same pieces painted with VHT Flameproof 1500 deg F paint? They'll still rust from the inside out, though. I am in Texas--there is almost never salt on the roads.
I want to get some estimate for the life of these pieces because I may exchange them for stainless versions, depending on how long the mild steel will last.
Old Jan 21, 2002 | 08:53 PM
SoCo80p's Avatar
if there just plain steel i would say about 2 years or so, if there aluminumized pipes the'll last a good 5-7 years most everything is aluminized
Old Jan 21, 2002 | 09:15 PM
sleeper's Avatar
I think he means fencepost... this would last at least 5 years... it's galvanized on both sides...
the paint will just flake off
Old Jan 22, 2002 | 01:43 AM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
If you start the car and make real short trips the exhaust won't last as long because they will be wet inside. If you always run it long enough to dry them out they will last longer.
Scamo-2.8
Dec 5, 2015 09:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
gixxer92
Sep 1, 2015 04:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
