question
Old Jan 21, 2002 | 09:17 PM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
question
i have a newly built 350, the oil pressure is fine when cold or with high rpms, but when its hot and idleing its under 10 psi, i just had the crank ground, it has new bearings, mains and rods, i changed oil pumps today, will finish tomarrow(high volume/high pressure pump) the old pump was 1 year old, the heads, were supposedly newly machined, has a new lifters and cam, i never had the rods checked for round, oh and i have a manual gauge on it, if the pump doesnt work what else could it be? thanks for the help
Old Jan 22, 2002 | 03:12 AM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
You might have an oil gallery plug missing. They remove them to clean oil passages and sometimes forget to put them back.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
