Ignition wires and timing
Old Aug 21, 2023 | 05:58 PM
Jayson_305's Avatar
Car: 1985 trans am
Hey all, recently sorted my issues with needing spark plug wires to fit with my headers. With that being said the wires will be here tomorrow and I’m anticipating putting them on. The wiring setup I had before was kinda messy and I’m not sure that the plug wires were routed right, although the car ran great. I’ve googled spark plug wire diagrams but I’m unsure of where the corresponding cyl 1 position is for my distributor. Is there any tricks to figuring it out? Thanks in advance!
Old Aug 21, 2023 | 06:18 PM
Re: Ignition wires and timing
Cyl 1 is supposed to be the front driver's side one. Firing order is 18436572. All that have to cross from one side to the other should go around the back of the dist exc #2.
Doesn't matter what your dist is. It only matters that whoever put it in, put it in at the right spot. Which should be, with the 12V & tach connections pointed straight to the driver's side, and the #1 in the place as described. Unfortunately, or fortunately depending on whether you know what you're doing, the engine will run just fine with it in all sorts of random orientations. If yours is installed weird, I'd STRONGLY recommend sorting that out before ruining a new set of plug wires making them fit some wacked-out loser's arrangement of garbage.
Photos of your current setup, w #1 labelled somehow, would help identify how it is now.
Old Aug 21, 2023 | 07:42 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
305? 1-8-4-3-6-5-7-2 ...
Old Aug 21, 2023 | 10:18 PM
Jayson_305's Avatar
Car: 1985 trans am
Cyl 1 is supposed to be the front driver's side one. Firing order is 18476532. All that have to cross from one side to the other should go around the back of the dist exc #2.
Between this and thinking it over, it makes perfect sense. The way it was wired before wasn’t like anything I’d seen online, but my connector is straight to the driver side and presumable distributor cyl 1 is in the correct spot, I think I found it out. That made perfect sense, I couldn’t find anything about the connector but that’s exactly what I was looking for. Thanks!
Old Aug 22, 2023 | 07:59 AM
Sorry, my brain got a cramp somehow... not sure how I can mis-type the firing order but I sure did...
Old Aug 22, 2023 | 10:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
For the inexperienced or backyard mechanic who is unsure of themselves, the best way to determine TDC is to remove the distributor cap so that you can see the rotor. Bump or bar the engine over until the timing pointer lines up on the balancer mark. The rotor will be pointing at either #1 or #6 cylinder.
It all depends on how the distributor was installed the last time somewhere else had it out. #1 can be anywhere on the cap as long as the rotor is pointing at it when at #1 TDC. Just about any position other than the 5 o'clock position just makes routing the wires more difficult.
As already mentioned 18436572 in a clockwise rotation is standard for the SBC. Be careful you don't mix up 5 and 7 because the plugs and cap rotation are right beside each other.
ERICSCHEVY
Nov 9, 2008 08:59 PM
Jammin'Trey
Aug 13, 2008 12:24 PM
redrummer
May 1, 2004 03:00 PM
kbog54
Dec 9, 2003 09:24 AM
kyrenegade
Mar 15, 2002 11:06 PM
