LT1 Water pump Coupler STUCK
Old Sep 20, 2023 | 07:25 AM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
OK so i goofed up. After changing out the opti i put the water pump back on with the coupler positioned backwards. so the water pump didn't go all the way back on . SO I pulled the pump back off and the coupler is now jammed on the water pump drive. it won't just pull off and my 2 and 3 jaw pullers wont grab it. I tried prying it off and the output shaft actually moved outward about 3 to 4 mm......now im wondering if i should just pull the drive out the rest of the way, separate the two in the vise and put the output shaft back in. Im guessing it's pressed into the gear that drives it? Advice appreciated. Thanks Pat
Old Sep 20, 2023 | 07:26 AM
hotrodln's Avatar
Engine: Lt1 in IROC
Re: LT1 Water pump Coupler STUCK
mcloudy21
Sep 15, 2018 11:18 PM
dixie wrecked
Feb 1, 2016 01:28 PM
mb2hurley
May 8, 2013 09:14 PM
NCcowboy
Mar 20, 2011 10:31 AM
