water pump or tstat
Old May 8, 2013 | 05:51 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
water pump or tstat
so my car decided to overheat on me today
theres plenty of water. i checked after it cooled down and started again and overheated. i dont wanna change out both if i dont have too
how do you know which one went to look for
the reseviour was bubbling, or boiling if you will and overflowing. i dont see any water coming from the water pump.
Old May 8, 2013 | 06:36 PM
ex-x-fire's Avatar
Re: water pump or tstat
Start by pressure checking the cooling system, you can rent those at autozone.
Old May 8, 2013 | 09:14 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Tstats are cheap, and easier than a pump. Is there any AF coming out of the tell tale hole on the pump ?
If bearings in pump are shot, it allows AF to flow out the hole ... indicating its failing.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
