Correct idle speed for 305 TPI (auto)?
Old Feb 5, 2024 | 04:31 PM
SkiingOnIce's Avatar
I can't seem to find it in my service manual. What is the idle speed supposed to be for drive and neutral?
Old Feb 5, 2024 | 04:33 PM
Re: Correct idle speed for 305 TPI (auto)?
Largely the same as any other EFI engine. 650 RPM or thereabouts in both N & D since the ECM cracks the throttle a bit more in D to keep the RPMs constant.
Old Feb 5, 2024 | 04:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Yup 650 warm, 100 rpm adder park and neutral. Warm iac counts 20-25. If minimum idle speed has been set properly then adjust tps to ,54vdc
Old Feb 6, 2024 | 08:40 AM
Vader's Avatar
Target idle is a function of coolant temperature, plus adders for park/neutral, fan anticipate, A/C operation, and keep-alive function. The "setting" is for minimum air position under specific conditions, then the ECM takes over. .
Old Feb 6, 2024 | 09:01 AM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
My stock 350 is at about 1000 rpms in park and about 725 rpms in drive.
Youngs92
Oct 3, 2017 01:00 PM
dexyman
Jan 24, 2014 12:32 AM
car86cars
Aug 14, 2006 11:44 PM
Camarothunder85
Aug 22, 2005 09:55 PM
