Car died now won't even start, strange issue.
Car: 91 firebird trans am gta
So my car stalled while driving, I was able to restart it enough to pull over before it died again and got a tow home. Once home couldn't get it to start at all, wouldn't turn over but cranks. Tested fuel pump, good.
Battery was drained to half so I took it in and charged it. When I put the battery back in the car, now when I turn the key I hear a grinding noise and then intermittent clicks from the starter, not even an attempt to crank. Checked all the main grounds they seem fine, haven't come loose. But the starter doesn't seem to engage and the gauge on dash reads less than 8 when cranking.
If it was a bad starter than the car wouldn't have died, but if it was a bad battery or alternator why did charging the battery not fix the issue, I don't get it.
Any other cables or things I should be checking?
P.S ive heard this grinding sound before when my car battery died, I believe it's just the starter not getting enough juice and engaging right.
Re: Car died now won't even start, strange issue.
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
The first thing to rule out the starter is either use a remote start switch or a screwdriver to arch the poles. If the starter engages and spins the engine, then you can rule out the starter.
SupremeC84
May 2, 2010 03:17 PM
