Engine won't start - died after one run today
Old Sep 5, 2006 | 02:31 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Coming back home yesterday, noticed lights were flicking together with the bass beat from the subwoofer. Today I went out to start the car, it did start but it ran real real quiet, low, barely alive. I drove around the block, twice, turned it off, started it again, and now it ran fine. I heard a loud hissing sound too.
Went to some stores, came back, parked the car, left it out in the back for one hour, tried to start it, nope, won't start.
Wehn I turn the key over, I do get the beep, loud and clear.
I measured voltage from the battery, 12 Volts with the ignition off, and seemed like 10 Volts or so witrh ignition on.
I also checked all fuses, they seem good to go.
It seemed though earlier today like the fan wouldn't stop running, but of course ignition off, made it stop running.
Alternator, old drained battery, 12V but not enough cranking power ?
Ideas , help ?
Old Sep 5, 2006 | 03:45 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
OK, ran battery power from my buddy's car, over to my battery, at first absolutely nothing, after a while I got as far as half a crank or so, so hmmm loose wires from the starter .. or something else ?
Old Sep 5, 2006 | 05:25 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Hooked up 12V from the battery, straight to the terminal on the starter, banged the hell out of it, and the car started, so obviously I need a new starter.
Would a bad starter, solenoid, do anything to the electrical system though, such as drain it ?
Old Sep 6, 2006 | 12:50 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
How do you test a starter/solenoid assembly ? Because it hmm COULD .. be the wiring
Old Sep 6, 2006 | 04:57 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
take it down to the auto parts stores and have them test it, they'll do it for free
if it was draining though, i would assume it is faulty wiring, not the starter itself
Old Sep 7, 2006 | 01:15 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Well it turned out to be the starter, I just got one and replaced it, and it made a huge difference.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
