Oil Temp Sensor, How Important
Old Feb 26, 2024 | 09:25 PM
marcos beltran's Avatar
First off i actually have an 82 corvette but i figured i would ask on here since early 80s trans ams and camaros also came with the Cross Fire Injection engines. My oil temperature sensor is not working. I know the gauge works, grounded wire and gauge shoots all the way hot. My question is i know in modern cars the oil temp sensor could affect the cold idle and could cause surging in low rpms, but on these cars does it have any affect on the ECM? Or is it just actually a sensor that only helps read the temp?
Old Feb 26, 2024 | 09:39 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Oil Temp Sensor, How Important
I never heard of a thirdgen with an oil temperature sensor. Your Corvette may be different...
Old Feb 26, 2024 | 09:52 PM
If this helps it is the sensor thats screwed to the block right above the oil filter. The trans ams and camaros do not have a sensor there?
Old Feb 27, 2024 | 06:46 AM
T.L.'s Avatar
Someone here should know.
I know some later thirdgens had a oil cooler, but I don't remember any temp sensor for it.
Of course I'm always learning something new...
Old Feb 27, 2024 | 07:46 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
1982 is probably a pre ECM engine. Since you know grounding the wire makes the gauge pin over, I'd say you need a new sensor. As for how it affects the rest of the drivability, without and ECM, no affect at all. If it has an ECM then yes it may change how it runs until the oil is at operating temp but I highly doubt a single wire sensor hooked to a guage is going to do that.
Old Feb 27, 2024 | 10:03 AM
Yeah it has an ECM, but you are probably right. It is a single wire going to the sensor and the gauge is analog. So most likely just for temperature readings.
whoaru99
Apr 27, 2013 11:53 AM
aammcc
Jan 20, 2010 04:54 AM
nascarfan7
Dec 25, 2009 07:39 PM
Desert86Roc
Jul 26, 2007 02:33 PM
phat87ta350
Mar 27, 2003 08:34 PM
