Oil Temp Sensor affecting tune?
Old Jul 25, 2007 | 04:30 PM
Desert86Roc's Avatar
IS $8D oil temp sensor input used in any calculations? I have a converted MAF -> SD harness, and my scan tool always reads the oil temp as -39*
I know I dont have a oil temp sensor, only ECM coolant temp and the gauge sensors. I checked the wiring diagrams posted on this site, but could not locate an oil temp sensor.
As I am just starting to tune a new SD motor, and it will not even run because it is pumping too much fuel, I had to wonder if that was one of the causes.
My motor is a HSR topped 406 with a custom grind cam.
286/294 (226/236 @ .050), 553/573 (w 1.6 rocker), 114 LSA, 110* centerline
Approx 9.8:1 compression. 30# SVO injectors
I know I probably need to cut fuel out of the VE tables, but how much to start?
Thanks for any input.
Mike
Old Jul 26, 2007 | 02:00 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Re: Oil Temp Sensor affecting tune?
The oil temp function was only enabled on the Vette....
Old Jul 26, 2007 | 02:33 PM
Great...thats what I was hoping. Thanks.
Bstrang6
Sep 8, 2015 04:29 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
