Carbed Intake technology old vs new
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
I run a Weiand 8000 0-6000 rpm dual plane.It is 90-2000s technology as opposed to the new 2024 Weiand 8125 or 8150?.
Am I losing anything?
Re: Carbed Intake technology old vs new
That used to be, and probably still is a well sought-after intake for those in CA, since it has an CARB EO number (and EGR provision). It looks a lot like the old 67-69 Z28 intake and the Chevy "Iron" intake, which ranked 21 out of the 23 intakes in an old intake shoot out article (based on peak HP), but did rank about the same as the Performer.
https://www.motortrend.com/how-to/du...d-comparisons/
Whether you're giving up much depends on your power level. I'd expect similar gains at this power level going from the 8000 to the Air Gap RPM. Good news is, you probably could get as much from someone in CA to break even buying a new intake.
Manifold PN ,,,,,,,,,,,,,,,,,,,,,,,,,,,,Peak TQ ,, Peak HP ,, Avg. TQ ,, TQ at 3,000 ,, Combined Power
Edelbrock Air Gap RPM 7501,,,,,,,508,,,,,,,,, 474,,,,,,,,, 471,,,,,,,,,,,,,,, 473 ,,,,,,,,,,,,,,,,,, 1926
Weiand Speed War 8150 ,,,,,,,,,,,,502 ,,,,,,,, 467 ,,,,,,,, 465,,,,,,,,,,,,,,, 467 ,,,,,,,,,,,,,,,,,, 1901
Weiand Street Warrior 8125 ,,,,,,, 501 ,,,,,,, 463 ,,,,,,,, 464 ,,,,,,,,,,,,,, 470 ,,,,,,,,,,,,,,,,,, 1898
Chevy Iron 14096011 ,,,,,,,,,,,,,,,,494 ,,,,,,,, 457,,,,,,,,, 459,,,,,,,,,,,,,,, 468 ,,,,,,,,,,,,.,,,,, 1878
Sorry, just realized you're probably asking about it on your 305. That test wouldn't really be applicable and it's possible if you went with a "bigger" intake you could lose some power in the lower to mid RPM band.
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
The best intake #s I have seen are from the Victor Jr intakes. I am running one on one of my foxbody mustangs. No numbers on that however. Don't have one on any of my thirdgens.
-R
-R
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1983 G20 Chevy
Transmission: 4L60
I am not saying every engine needs a Dominator either, but look at the testing Eric Weingartner just performed. Dual plane with a Dominator was a stump puller on his test engine. I wish he had tried a header evac system on that combination as well, bet it would have added a bit more average power.
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Engine: Slow ones
Honestly the real bottle neck is not using some form of Modern EFI like holley etc. Keep the old school look with modern tech. On any intake it will be a beyond improvement. Especially with all the deals out there
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1984 Z28
Engine: L69 305 HO
Thanks guys! I have no use for an Air gap manifold, due to weather considerations.
I have a Weiand 7525 if I want to go single plane manifold. Not recommended.
Fuel injection not an option. I know nothing about it. I have been using holleys for just over 50 years.
Weiand 8000 paid for, and great performance.
Hood clearance, the 8000 fits just right. I will research the Eddie RPM spreadbore and the weiand products!
Thanks for the advice Gents! Keep em coming.
Engine: Slow ones
I 100% doubt that. The Holley EFI systems literally learn and adapt to how your car is running and can adjust just about everything by themselves. They will always be more efficient and spot on
Car: 1984 Z28
Engine: L69 305 HO
wWhy don't we leave the FI debates outta here. I know nothing about it, I wouldn't use i1 if I had one..
OFF Topic.
OFF Topic.
jwilliams417
Jul 18, 2009 11:15 PM
