Opinions on Fitech Go Street EFI 400HP
Subscribe
Mar 16, 2024 | 02:51 PM
Hey gents, need some help!
I'm in the final decision process of going with an ATK 383 / EFI engine for my 84 Camaro Berlinetta (305/700r4).
Engine link: https://atkhp.com/product/atk-hp94c-...ech-efi-415hp/
ATK site says I need the electric fuel pump for this, but pretty sure more is needed, right?
EFI System: Fitech Go Street EFI 400HP (throttle body, wire harness and hand held unit included)
From what I've read I also need to modify my fuel tank to handle the EFI, which I understand requires the send & return lines to the tank.
Anyone done a Q-Jet to Fitech swap? What else do I need to do this?
Any help appreciated! Thanks in advance!
Jim
Reply 0
Mar 16, 2024 | 03:27 PM
Re: Opinions on Fitech Go Street EFI 400HP
I swapped my 82 TA years ago w an Edelbrock system and originally used an inline pump. As time went on I updated the EFI and ran new lines and used and aeromotive stealth tank with a built in pump. The aeromotive setup is great. They sell it as an entire setup or just the pump/sender. You're gonna need to run at least one new line so you basically have 2 6AN lines from the tank to the engine, I believe the stock feed is close enough. You need two lines that size to prevent the pump from overheating and to allow the pressure regulator to do its job. I ran 2 new 6AN lines. Aeromotive recommends that size up to 750 hp.
I have 450hp and it works great, the engine is gonna get some boost soon and the fuel sys should be adequate.
you'll need a full fuel system basically. Pump/line(s), filter(s), a regulator and relay/wires.
it's all pretty easy, just a bit of time.
Reply 1
Mar 19, 2024 | 10:52 PM
I’ve daydreamed of an FI swap.
I’ve considered the 4th gen tank for the in tank pump… swap to fi hose and reuse factory fuel tubing and the corvette filter/regulator…
Leaves the car closer to stock, parts store components make it easy to maintain and oem reliability.
Reply 0
Subscribe
