Zexel Torsen install
Old Apr 15, 2003 | 07:11 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Installing the take off Zexel differential from
SLP and 28 spline Moser c-clip axles. Just removed the c-clips from the old rear and immediately noticed they will not fit into the tiny c-clip slots on the Zexel. Does the Zexel have different clips ?
Also noticed when I slid the new axles into the
Zexel just to see how they fit, the slot on the end of the axle does not come into view. I do not
see any way that any c-clip will slide in and
secure the axle. Looks like the piece that the
cross shaft bolt retains is incorrect?
Old Apr 16, 2003 | 02:14 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Are you trying to install 3rd gen 28 spline axles into a 4th gen rear? This will make the axles a little shorter than before...
I had no problems with the stock 28 spline axles in an 89 rear.
Old Apr 16, 2003 | 09:40 AM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
I have the correct size axles for a third gen. And
the rear is the one that came in the car (84). The
only part from 4th gen is the Zexel differential.
Seems to be an incompatablity between the axle
ends and the differential.
Old Apr 16, 2003 | 10:29 AM
TBI305Camaro's Avatar
How much did the new axles cost you? I have a 88 rear so I have the 26 splines. I would like to upgrade to 28 spline axles and run a zexel differential also. If not I guess I can go to a junk yard and try to find a newer model axle again. So far Ive had 0 luck with that. Local place wanted 350$ for a 95 v6 rear with drums. Oh plus trade in LOL
Old Apr 16, 2003 | 10:46 AM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
$ 259.00 with studs and shipping.
Old Apr 16, 2003 | 12:01 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Hey, all the Zexel Torsen owners, someone has to have some enlighting info.
Are the c-clips different from a 3rd gen to a 4th
gen rear?
Old Apr 16, 2003 | 12:11 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
not that i know of... man i just used all my stock stuff except the posi and axles... they worked just fine... the stock C-clips from the rear from the car... '89...
Old Apr 16, 2003 | 07:21 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Got it, little block thing comes out, c-clips go on,
block thing goes back in.
Next thing I noticed, when comparing axles, the Mosers
are about 1/8 inch longer to the outside flange. This will
make the brake discs stick out and possibly interfere
with the calipers.
Old Apr 18, 2003 | 12:56 AM
I might just try to find a newer rear so I dont have to swap the axles. If I can find a decent rear anyways. Im having trouble.
I finally got my tranny. Installing it tomorrow. It will be nice to have my wheels again.
Old Mar 20, 2024 | 12:00 AM
itsjoeyjoe's Avatar
Re: Zexel Torsen install
do you know the length of your stock 28 splines in you 89? I have a torsen zexel 3rd Gen I’m trying to install in my 87 Camaro it’s a 7.5 10 bolt
or if you have a purchase link to some that would help me out a lot thanks.
i tried to use axels from a 4th gen and they were too long
Old Mar 20, 2024 | 08:25 AM
https://www.summitracing.com/parts/s...ion-drivetrain
Old Mar 20, 2024 | 08:33 AM
itsjoeyjoe's Avatar
Thanks for the help with my build
I Appreciate it !
bracket rs
Mar 4, 2015 03:53 PM
jamon8
Jun 30, 2008 05:54 PM
collin0825
Jul 13, 2005 09:27 PM
92rs85berlintta
Apr 23, 2005 12:10 AM
1MeanZ
Oct 8, 2002 10:54 PM
