axle questions
Old Oct 8, 2002 | 02:59 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
axle questions
hey guys i just got a posi out of a 4th gen car and i obviously need the 28 spline axles. can anyone tell me the exact diameter and length of these so i know i am getting the right axles that will fit my 86 7 5/8 rear. my car also had drum brakes, does that make a difference?
Old Oct 8, 2002 | 05:49 PM
chacane67's Avatar
Old Oct 8, 2002 | 06:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
4th gens have 10 bolts. There's no 9-bolts in them. 9-bolt ring gear dia is 7.75".
Anyway, the only axles that will work are ones out of a 90-92 F car. They'll be the same length as yours, and the same diameter at the bearing; they won't neck down like yours do though. The spline section will be larger diameter. And of course, they'll have 28 splines.
You're going to have a REALLY hard time coming up with junk axles. Most boneyards won't sell them, they'll only sell whole rears when they're high-demand ones like these cars. So what you'll end up having to do is buy a whole rear, take the axles (the part everybody wants anyway) and just leave the housing and all that behind. Any 3rd gen 90-92 will work, the axles are all the same; look for 6-cyl RSs and other bottom-line cars.
Old Oct 8, 2002 | 09:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can also order better 28 spline axles from places like www.tomsdifferentials.com Part number KAC7-A7
They're only $125 each and much better than 90-92 axles if you can even find them. The aftermarket axles will fit drum or disk brakes.
Old Oct 8, 2002 | 10:54 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
thanks for the replies guys. i have found a set i will prolly buy. i just wanted to be equipped with the knowledge so that when i go to pick them up i am not gettin screwed. i want to be able to identify the axle i need for my application and i wasnt sure if there were any differences in the 28 spline units.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Genopsyde
Oct 7, 2015 08:35 PM
downsouthboy
Aug 29, 2015 11:29 AM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
